RPM sensitive Honda Outboard Noise after propeller change...
rickbartholomew
Post by rickbartholomew »
I recently (yesterday) replaced the original(ish) Honda 3 bladed 11.8x13 prop on my 2001 Macgregor :macx: with a new Honda 4 blade 11.8x9. The propeller swap was a snap (out of water), and the motor passed it's "Garbage Can" run prior to my wife and I launching her yesterday. I how have what sounds like a (loud) bearing noise at RPMs between 1500 and 2200 RPM (while in the water). No problems at lower or higher RPMS. There is no similar noise in reverse, nor when run out of water (with a hose supplied "ear muff" flushing adapter). Thrust Bushing problem? Thoughts? Are there any particular tricks to propeller replacement on Honda BF-50's that I missed? I've pulled and re-installed the prop (in water) with no change. All parts appear to be installed correctly.
Rick
Retcoastie
Re: RPM sensitive Honda Outboard Noise after propeller change...
Post by Retcoastie »
Did you torque the hub nut to 25ftlbs?
ROAD Soldier
Post by ROAD Soldier »
I had the same problem with both 4 blade props that broke on me. I definitely could not troll for fish at that RPM would scare the fish. Good luck with that 4 blade kid. When you had enough of it get a 3 Blade 11 3/4 x10 prop.
rickbartholomew
I'll check the torq tonight, and will experiment this weekend with our old 3-blade prop.
Thanks, all.
Rick
DaveB
Post by DaveB »
Rick, I had winning noise around the 1000-1300 rpms on two of the Solas alcup 4 blades.
rickbartholomew wrote:I'll check the torq tonight, and will experiment this weekend with our old 3-blade prop.
Thanks, all.
Rick
opie
Post by opie »
Dave is right about a 4 blade propeller (especially Solas) giving out strange sounds at about 2k rpm. (See this (LINK)
I experimented and ground off the cupped edges of the 4 blade and the noise almost disappeared. I will stick with 3 blade props, thank you. So I think you can be relieved to know it is not a Honda mechanical problem.
Is their a thrust washer that goes on before the prop did you reinstall it it maybe stuck on the old prop !!!
Terry
Post by Terry »
opie wrote:Dave is right about a 4 blade propeller (especially Solas) giving out strange sounds at about 2k rpm. (See this (LINK)
The function of the cupping on the trailing edges of the propeller is to provide more grip so that the prop gets a better bite on the water and have less slippage which translates into more forward thrust. Grinding the cupped edges merely defeats the purpose. I have a Solas Alcup 4 X 11.4 X 10.5, I had the pitch altered by a prop shop so it is not factory standard but it works well. I might wonder if perhaps the larger diameters are a contributing factor. With my 11.4 diameter I have more clearance between the prop edge and the anti-cavitation plate and so no noise. Perhaps with the larger diameters the singing noise is a result of the prop edge breaking the surface of the water just under the plate. I have looked back at the engine while at WOT and noticed that the anti-cavitation plate is just skimming over the water surface like a ski so there is not much room for clearance. Those 12 inch diameters are almost touching the plate so if there is any air rushing under the plate the tip of prop may be sucking some of it. Just another theory though, I could be wrong. Personally I don't think the Honda swings a large enough prop, I think they should have a larger clearance under the anti-cavitatuion plate to accommodate a 12 inch prop with at least a half inch clearance to spare.
DaveB
Post by DaveB »
Terry, my 11.8x10 Solas 4 blade has a 7/8 inch clearance from Cavitation plate. Previous owner raised the engine 1-1/4 inches off the transom and when motor is all the way down and you eye ball the cavitation plate the clearance to bottom of hull is only 1/4-3/8 inches and should be min. 1 inch. I could lower the motor back were it is suppose to be or tilt the motor back slightly.
I have no idea why they raised the engine but I feel the boat was always empty when they had it and got on plane faster and higher speeds.
Reverse, it cavitates very easy. I will wait until I install a new motor .
The winning noise came from the hub to shaft and bearings and after 3 blade changes it stopped winning but barely could fit the propeller nut and cotter pin it as hub was 1/8 inches from engine.
The 11.8x10 solas 4 blade has to much pitch to get to low end of the rpm limit. Ok for me as I like low end thrust for cruising 6 knots and lower rpm for sound noise.
Theo
Post by Theo »
I have a Solas 4 X 11.8 X 9 also and it has a similar phenomenon. It "sings" right around 1800 to 2000 RPM. I kinda like it. That is right where my X is doing 5mph or the "wakeless speed". Nice aural reminder of where I am at speedwise.
Other than that I am pretty happy witht the prop. It is geared a touch low. I am a little leary of maxing out the rpms at around 7200 but I have had it up to about 6900 (just a hair under 7000) and I am doing about 16 mph no ballast but a fully loaded boat with 5 people and all our fishy gear. With ballast in and 4 days worth of gear on the open Pacific I can do 12 mph at about the same rpm (~7000). I am thinking about bringing it to a prop shop and having it geared a little taller. I have noticed that I am using more fuel than with my old prop. Not high on the priorities list though.
Theo
MSS
Location: Europe / Sweden 2002X - Honda 50EFI - MACX4868B202
Post by MSS »
Hamin' X
Post by Hamin' X »
Thanks for the link, Mattias. Looks like a credible source.
