nedmiller wrote:The PO put a Teleflex "no feedback" 4.2 steering with a 22" wheel on SILK and it has advantages and disadvantages.
Pros: You can let the wheel go at anytime and it sticks right where you left it. If everything is balanced, you can go a long time with little or no input.
Cons: No feedback. I mean NO feedback. The boat we sailed before had tiller steering and I found it very hard to sail this
with wheel steering and no sense of how much pressure you were applying or how much 'pushback' you were getting from the force of the water on the rudder. It might have been a lot better if I had gotten a lot of experience with the Mac first and then been introduced to the no feedback steering. I think the no feedback system made it harder to learn to sail the boat.
Even with the upgrade, I am really not happy with the way the steering feels and since I've not sailed a mac with regular steering I don't know if it is my system or Roger's crazy boomerang arrangement....
SILK
Food for thought...thanks. I get LOTS of feedback from my current steering and its all bad. It is VERY sloppy and almost impossible to control under power without the rudders down.
I'm hoping to make it a season or two before being forced to upgrade to the late X style steering. My rudder brackets are all bent up. They work but I know the geometry is not right.
I found some Zinc plated 3/8 x 3" pan head bolts, to replace the S.S. part that actually broke. I would have used S.S. if I could have found it, but zinc plated will probably last a year or two with the occasional use I expect. It will also be more likely to bend, rather than break, so that may be a benefit. I figure that by the time it is rusting out I'll be replacing the whole mess anyway. But I got a couple of spares...just in case.
I'm going to try jamming my steering linkage in various positions and pushing hard on the wheel. If nothing happens, I'll try keeping the current steering box for a while. I think I'll also work on a "plan B" in case it fails. If it "clicks" when I stress test it, I'll have to replace the steering "box". Despite your warning, I'm still leaning towards the zero feedback, I think that being able to leave the wheel for a few seconds will be a TREMENDOUS help. I have a "friction screw" that the P.O. purchased and never installed, but that just seems so cumbersome by comparison.
I suppose I'm, still weighing my options...
