26 m Rolling mast [Rotating Mast}
simsim
Post by simsim »
I buy a Mac 26m since three weeks. But the rolling [rotating] systeme mast don't work. Do you help me?
I try to adjust upper and lower shrouds and they don't work better.
Sorry for to my poor english I'm a french Candian.
Thanks.
Reason: edited for clarity
Crikey
Re: 26 m Rolling mast [Rotating Mast]
Post by Crikey »
Can you provide any pictures or further description? Matt in Quebec1 may be near you and able to render some better assistance 'en Francais'.
I don't think Roger Macgregor does bi-lingual instuction manuals (Tabernac!) but I may be wrong and it could be worth a call to California to find out....
Ross :wink:
Re: 26 m Rolling mast [Rotating Mast}
SImSim..my French is poor, but I try.
Ce qui est la vitesse du vent ??
En vent leger, il ne aucune rotation(?)
Aqualung
Post by Aqualung »
Bonjour SimSim,
Par vent faible le mât ne suit pas l'orientation du vent.
Le principe de rotation du mât n'est pas très efficace comme le pense son concepteur.
J'ai un M26 sur le Lac Champlain et j'ai la même situation avec mon mât.
Michel.
Capt Sully
Post by Capt Sully »
Say What :D
Hamin' X
Post by Hamin' X »
He said that it's not very efficient and that he has the same problem.
Divecoz
Post by Divecoz »
Hummm
Hamin' X wrote:He said that it's not very efficient and that he has the same problem.
u12fly
Post by u12fly »
HAVE YOU TAKEN THE BASE OF THE MAST APART? It should be a single 3/8 bolt plus a small sheet metal screw. Once the base is off you should be able to remove the vertical bolt which seperates the mast attachment from the base. There is a washer in there that should be clean and well greased for easy rotation.
Jack Sparrow
Location: Cairns, Australia 2007 M 50 Yamaha Run to Paradise
Post by Jack Sparrow »
Only one answer it needs a modification.
Jack Sparrow
u12fly
Post by u12fly »
Jack Sparrow wrote:Only one answer it needs a modification.
Jack Sparrow
And Jack is the master of Mods! This is the one you will want to reference:
http://www.macgregorsailors.com/modt/in ... ?view=1059
Chris.
simsim
Post by simsim »
Tanks I try to grease my washer and I Will go with feed-back
But anhoter question, the problem can be cause by a bad angle of the mast ?
Like to tight forestay
Thanks
Mine didn't rotate until I installed a bearing washer. Lubrication and loosening the bolt might help.
