easier pin'ing of the furler forestay (26X)
X with bow roller/cdi furler
my forestay needed to be tighter on the water, but when shortened, no way could I pin it on my own even with the removal of the backstay. in the end, I found I could tie off a rope to the front mast support brarcket, run it around the bow roller to a loop formed around the cdi furler drum and back around the roller, cleated off. . This pulls it to the coorect height but an inch or so out of line, but its easy to push the drum so the holes line up so slips in with one finger.
I will finda small ratchet strap to do a similer job.
- JohnCFI
Re: easier pin'ing of the furler forestay (26X)
I use the trailer winch webbing run up and over the bow roller, does the same job.. Needless to say I have a second line attaching the boat to the trailer (I never depend on just the winch to hold the boat on the trailer).
- mastreb
Mike Inmon suggests using a dockline tied above the furler down to the trailer, and then putting your foot through the eye to pull the furler down to the tang. This leaves both hands free to pin it.
That foot trick is magical. Two hands make pinning the furler a cinch.....
- JohnCFI
I have tried this, and found that my 110Kgs is just not enough, The winch is a cinch though!!mastreb wrote:Mike Inmon suggests using a dockline tied above the furler down to the trailer, and then putting your foot through the eye to pull the furler down to the tang. This leaves both hands free to pin it.
- Sumner
...............a Johnson lever....................,
Sum
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
Sum
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
- yukonbob
Tie around the furler, through the anchor roller and back up (most people can pull it down and get another to pin) or if you have a long enough line back to one of your winches for a little extra pull. This can be done off the trailer, which after many times of setting up on the trailer, I am consistently leaning towards on the water setup.
this was more about being on the water rather than on the hard. Many times I had to pin after going through brigdes where I was, and now permantely in a slip. so worth mentioning for those that struggle on the water. makes life a lot easier/rig tensioned.
- Wind of Freedom
@133bhp: I don't understand, if this is about re-pinning the forestay on the water, then why do you mention the "bow roller" in your original post? The only bow roller I know of is on the trailer? Please enlighten me ... you got me curious ... LOL.
- Azzarac
- Location: "Chameleon" in the Middle of the Mid-West w/Honda BF50
Like Sumner said... Johnson lever http://www.defender.com/product.jsp?pat ... &id=204892 Works on or off the water.
- Sumner
I haven't seen that one used before. Are you using it with a furler? I'm having a hard time visualizing how....Azzarac wrote:Like Sumner said... Johnson lever http://www.defender.com/product.jsp?pat ... &id=204892 Works on or off the water.
...it would work with the furler drum. Is there much leverage with it and is the rig tight or do you still turn the turnbuckle?
I think the one I've seen most use is....
http://www.defender.com/expanded.jsp?pa ... &id=205123
....the #14-205 (above). We went with one a couple inches longer, the ....
#14-210 as it is rated for the 5/32 forestay we are using. Here is a link...
http://www.csjohnson.com/marinecatalog/00032.htm
Defender doesn't stock it but will order it. Both the 205 and 210 give you a lot of leverage and it is easy to pin and still get a lot of tension on the rig. More than you can get just pulling down. Before when I would pull the mast up with the gin pole and block and tackle I would still turn the turnbuckle after pinning. It wasn't that hard to do with the hank-on sail but would be real hard to do with the furler drum. Now I don't have to do that
Sum
Our MacGregor 26-S
Our Endeavour 37
Mac-Venture Links
- mastreb
The boats really ought to come stock with a Johnson lever, considering how often one has to do this.
- Hamin' X
The bow roller is an option for the anchor and is attached to the boat.
Smorgasbord business model. Macs in slips wouldn't benefit while trailer sailors obviously would benefit.The boats really ought to come stock with a Johnson lever, considering how often one has to do this.
- Azzarac
Sum,
I followed Laika's modification on this site: http://www.macgregorsailors.com/modt/in ... ?view=1547 and it works fine.
