The engine is a Mercury 50 BF, with a 14x10 prop.
The boat is in a wery good shape , same the engine ( only 110 hours ).
The boat is equiped with a roller jib and the main sail.
I tested the boat in light wind : wery easy sailing with good speed ( 4,5 - 5 mph ).
Underpower with ballast full: 15 mph at 5300 rpm
With ballast empty and my family : 17,5 mph at 5300 rpm.
With boat empty: 18,5 mph at 5300 rpm.
The bottom is painted.
The only trouble i have is: i read on the engine istruction that it can run till 6000 rpm.
Mine doesnt run over 5300.I cecked every trim position: always the same. no more than 5300 rpm.
i asked to the mercury dealer , he told me it depends on the boat shape.....i think this answer is not correct.
