Top Mast Cover?
Top Mast Cover?
This is my third season with the 26X and have always had her in a slip so I don't do much trailering. This year I was thinking of running my antenia up to the top of the mast and notice that there is nothing on the top of the mast. Is there suppose to be a cap up there or something? If there is where would I get a new one? It just seemed a little odd that the rain and elements could get in there.
God speed
God speed
- Jesse Days Pacific Star 2
- Tom Root
- Location: Annville, PA. s/v-Great White, MacX4787A202,'09 Suzuki DF-50
Only the older Mac Ventures came with a cap on top of the masts, as far as I am aware of? It is unneccasary, as any rain will simply exit through the bottom. But, if you wanted to provide flotation as the M Mac does, simply spray foam into the top and bottom, a couple of inches should do it! Then seal all other fastened items with RTV? Been considering that option myself actually!
I don't know if it is unneccasary. One of the problems I'm having this year is the wire from the deck to the mast light is broken, and I need to replace it. I was thinking that the problem might be that the rain is getting in there and corroding the wireTom Root wrote:Only the older Mac Ventures came with a cap on top of the masts, as far as I am aware of? It is unneccasary, as any rain will simply exit through the bottom. But, if you wanted to provide flotation as the M Mac does, simply spray foam into the top and bottom, a couple of inches should do it! Then seal all other fastened items with RTV? Been considering that option myself actually!
God Speed
Me
Paul
Is that me in the picture??. I know it's my mess in the background. I'm not only barbarick with my mast drilling... I'm messy as well.
Paul S
Re: Me
Yup..thats you..ensuring the antenna wire would mate to the bottom of the antenna.BobCardz wrote:Paul
I did finally get the wire attached to the connectors. Put a little wd40 and it went on a lot easier. Very tight fit.
Also got the 4 pole mast light/anchor light/foredeck light connector installed. Came out pretty good.
I'll have pics of the recent modifications up soon.
Taking the boat out for it's maiden voyage this weekend with the New England Trailer Sailors club at Allen Harbor RI.
Take care
Paul
BWY told me the early X's came with a cast cap, but it was discontinued. I managed to scrounge an old one that had been mis-drilled and repaired it and used it for my anchor light. BWY also sells a standoff that allows the sparfly to be mounted further aft so it won't hit the light as it rotates. If I didn't have the old cap I would try to fabricate one.
