Better late than never...c130king wrote:
No impact on sail shape at all. In fact, when the sail is up the LJ lines go fairly slack like the topping lift. They weight of the boom pulls them tighter when I lower the main.
I will post pics of the upper attachment area and the "cross lines" that attach to the shrouds and a pic of the sail and how the LJ lines are somewhat slack under sail tomorrow.
Here is the pic of the top part of my LJ system. The top end is attached to the mast about halfway between the spreaders and the top of the mast. Line is attached to a simple fairlead type thing attached to the mast. Lines run down to a little below the spreaders and end with small blocks. Then there is a 2' -ish line tied just above those small blocks and pulled out and tied to the upper stay/shroud. These lines pull the slot open as I mentioned.
The "main" LJ lines run from the front end of the boom up through the small blocks and back to the end of the mast. One line for each side. The end of each line is a simple/cheap carabiner (bought in the camping section of WalMart). They connect to simple fairlead type things attached to each side of the boom at the front and rear. Easy to clip on and off. When off I can pull the lines up to the mast and the sunbrella cover goes over the top of them and they are held in place by the cover up against the mast.
The vertical lines are tied to the main LJ lines with simple granny knots and run under the boom through the same type of small fairlead type things. I have taken a few wraps of duct tape (about 1" wide) around the main LJ lines to keep the granny knots from sliding down.
This second pic shows my Dad at the helm and you can see the LJ lines on the leeward side just up against the main. Yes, they touch. But no there is no chafing or issue with this and there is no impact on sail shape. But maybe there are sail shape purists that could not abide with this.
As to some other comments that were made. I guess if there was a 25 knot direct tail wind then maybe the flaked sail being held in place by the LJ system and NOT tied down could possibly catch some air and flap around or maybe even partially "inflate". Never seen it happen. Not an issue that I really worry about. Once the sail is down I normally throw a couple of bungees around the sail to hold it in place. Not really necessary IMHO. And I don't have to leave the cockpit...just reach as far forward as I can for the first one that is far enough to keep the sail from flopping around in a big tailwind.
And I respectfully disagree with DaveB about the windage of the LJ lines. The boat has pretty good windage already from the mast, the furled foresail, the flaked main on the boom, the boom itself, and of course the high sides of the boat. The LJ lines maybe add about 0.364% increase in windage area (0.429% if you use 1/4" line instead of 1/8" line...
And I only raise and lower the main when directly into the wind so I can't really comment on how well the LJ system works if you tried to lower the main with the wind on the beam. I think the slugs would have too much pressure on them to fall anyway.
Maybe about 20% of the time when raising the main one of the sail stiffners (actual item name escapes me right now...I guess your memory really is the second thing to go) will hang up on the intersection of the main LJ line and one of the vertical LJ lines. But I simply let the main back down a foot or two, let the main flop back over towards the center of the slot, and haul away again. Not really a problem IMHO.
They really do make my life much easier when single-handing. No worries about the main flopping all over and catching on things when it comes down.
Sailing on König
