I am / was an Electrician for almost 40 years.. we have all kinds of great toys for facilitating fishing expeditions .. I seldom mention them by name as most are too costly for a fellow who may well only use it once or twice in a life time.. I used my Green-lee Fiber rods to drill 16 feet thru some sort of hard foam(?) core between two decks/ liner and deck top.. I fashioned a crude bit out of a 10/24 stain machine screw that screwed into the coupler and we used my magnet from "HULL" aka Very Strong... with a handkerchief between the liner and the magnet ( so as not to scratch the liner) to direct the "bit" as I drilled it forward to where he wanted to get.. then I used my Carborundum hole saw to open the liner and attach a wire " with a #$%^&*( pull string!) for later.. I got....... 1 Qt. of Jerry Sailor Rum, 1 Qt. of Raspberry Vodka and.... a Case of Beer for my effort
bartmac wrote:In Australia electricians,antenna installers,computer cabling guys use the tongue from particle board flooring...its a hard flat plastic material 5/8" wide and about 3/16" thick...reasonably rigid,drill a hole in one end ,attach said wire and start poking it in the general direction required.I found after a while you get quite good at aiming.I've now rewired and added wire to all corners of our 26X with out too much trouble.Mind you the removal & replacement of floatation is time comsuming.One thing....does the US use particleboard flooring.....maybe a different name
