Unidentified Tubing
Hamin' X
Unidentified Tubing
Post by Hamin' X »
OK, here is my dumb question for the year, well the week anyway. I've been cleaning and prepping my 2001 X for spring launching and have noticed for the first time a strange length of clear plastic tubing protruding from the top of the starboard aft berth. Didn't measure it (Doh!) though it appears to be about 1 1/4 inches. What the heck is it?
Capt Capsize
Re: Unidentified Tubing
Post by Capt Capsize »
It is the tubing which allow passage of the control and battery cables to the outboard, if you route them from the pedestal toward the back. The other end (outside) of the tubing should be located just to the right (starboard) of the outboard about 3 or 4 inches above the deck. :macx:
Hamin' X
Post by Hamin' X »
Thanks, that makes sense. My boat was sold by BWY and they run the control cables on the cockpit sole, covered with a U-shaped starboard channel.
Hamin' X wrote:My boat was sold by BWY and they run the control cables on the cockpit sole, covered with a U-shaped starboard channel.
Interesting.
That must be an X thing because BWY installed my M's cables down through the pedestal (toothbrush style) under the cockpit floor and into the motor well.
That tube might be handy for running other stuff though.
My guess is its the mens urinnal for when the head is preocupied !! :D :D :D
Hamin' X
Post by Hamin' X »
Highlander wrote:My guess is its the mens urinnal for when the head is preocupied !! :D :D :D
Well, yer gonna have to stand on YOUR head then. :D
I believe this is factory kit, Rich - I think my 2002 has this although in a slightly different location. Im sure there is an ISO documented change for the position of the hole on file in Brussels.
Hamin' X
Post by Hamin' X »
Catigale wrote:I believe this is factory kit, Rich - I think my 2002 has this although in a slightly different location. Im sure there is an ISO documented change for the position of the hole on file in Brussels.
Just my luck, as I don't read Flemish. :o :D
gyroplanes
Post by gyroplanes »
Spider mass transit tunnel?
I hate them &*&%%^& things.
Sea Wind
Post by Sea Wind »
Hamin' X wrote:Thanks, that makes sense. My boat was sold by BWY and they run the control cables on the cockpit sole, covered with a U-shaped starboard channel.
Do you have any pictures available ?
Sea Wind
Hamin' X
Post by Hamin' X »
I'll try and get some posted this week.
Hamin' X
Post by Hamin' X »
