Casey,
What kind of paint did you use in your bilge? I'd like to paint mine also. Do you have any lessons learned to make the job easier?
Tim
Is Your Mac - Wet or Dry?
- argonaut
More leaks!!
OK, after last weekend's thunder storm I checked and had a gallon of rainwater in my starboard aft bilge.
Seems to be running along the cockpit's liner all the way aft, then dripping down into the bilge, there was also some directly under the binnacle entry.
Any ideas of good leak sources? The lockers wouldn't leak that way would they?
