Does anyone have an accurate Plan of the Macgregor 26M saloon Table that I can have
regards
richard
Plan of Macgregor M saloon Table
- RobertB
Re: Plan of Macgregor M saloon Table
Do you just need a drawing of the existing table? Or is this something other than stock you are looking for? If stock, I can measure mine, should be easy.
- r.fairman
I need the dimensions of the stock table the shape is some sort of trapesoid
thanks
thanks
- c130king
I am about to drive over to the marina for day of potentiallly rainy sailing. I will take some measurements. But my Dad and I remade the table from my
Sailing on König
- mdeane
c130king wrote:![]()
I am about to drive over to the marina for day of potentiallly rainy sailing. I will take some measurements. But my Dad and I remade the table from my. It is exactly the same size but over 2" thick as it has a lift top for storing charts and paperwork inside. And it has fiddles on the edge. I had intended to get a sheet of plexiglass so I could put a chart on the table and then cover it with plexi...the fiddles would hold it in place. But I never did that.
Sailing on König
Can your tabletop design still be used as the starboard berth filler board?
Marc
- mdeane
r.fairman wrote:Does anyone have an accurate Plan of the Macgregor 26M saloon Table that I can have
regards
richard
My 2005 M tabletop is 39 1/2" x 30" . The front corners are 8" radius quarter rounds.
Marc
- c130king
Marc,mdeane wrote: Can your tabletop design still be used as the starboard berth filler board?
I don't think so. I have never put the original table or the new table in that position...and I don't have the cushions for it either. But the new table is probably about 2 inches taller/thicker than the standard table and that is not counting the 1/2" high fiddles.
