It looks to me like the main is about one foot short, a lot more than an inch.
Can other
I have often tried to pull the main up against the main sheet or the vang..is it hard raising the main the whole way up the mast or just the last few feet?
Well, my 26m arrived also WITHOUT sails slugs - unfortunately. Had to bring the main to sailmaker... Was worth any pennymika wrote:It sounded like some of you implied this man's new boat was delivered without slugs on the main. Is that possible? My new M came with them and I don't recall that having been an upgrade when I ordered. Hmm.
If you want to know my opinion, it isn't about lubricating. Lubricating can make in 30% easier, some dirt can make it 30% harder (and you have a new boat!), but when it takes four guys and 30 minutes to do what you should be able to do singlehanded - then something is wrong about the rigging.apauwels wrote: Some of the advises, I already tried after my first sail. The halyard indeed seems to look for that bolt in the top to get stuck. I had the mast down and visually check if there is anything stuck in the groove, I point her straight in the wind to prevent any load, etc... However, I did not try to run one slug up and down. Maybe that could solve or show something. I got one major sailing tip which was to use soap as a lubricant. No stains, and theoretically washes out with rain (it never rains in Dubai), but still after each sail the boat gets hosed down, so that's wet enough. I will try that over the weekend
Maybe I rigged her wrong. When under full sail, the Genoa seems to be fighting and rubbing the bow rail. Does it look the same on any of your?
Looks good! By they way, welcome to White Hull Community. Everybody knows that beautiful girls get crazy only about white hull Macgregors.Below picture is the Mona Lisa under sail, after pulling at the main for about half an hour with the full crew. As you can see the Genoa is rubbing the bow rail and if you look closely, you can see that the main still had about an inch or so to go up.
This one isn't working for me.Direct image link: https://www.dropbox.com/s/ciz6o73gjx12n3u/IMG_4144.JPG
Welcome.Thanks very much to everybody once again for the tips and warm welcome.
Are you kidding or what? Mine (2011 make) arrived without any kind of slugs whatsoevermika wrote: It sounded like some of you implied this man's new boat was delivered without slugs on the main. Is that possible? My new M came with them and I don't recall that having been an upgrade when I ordered. Hmm.
DrV wrote:In March, I am coming to Dubai on business, if there is still need - I don't mind to take a look. I'll be fun for me, too (too early to sail in my area!!!).
It is 100% clear what you mean, after you published that picture. Why do you think that it is that important to feed last foot of the mainsail into that slot? I don't think that I would gain anything, even if there is a way to do it. So, I sail without that last foot feeded in. At least, I can give you a guarantee that it is EASIER my way.BOAT wrote:If you look at this picture, you see that the rope on the luff side of the tack must go DOWN the slot. The rest of the main goes UP the slot. Am I making any sense??
You see? there is a big area (the "bunch of space from here to here" in the picture) where the sail would not be in the mast slot if you only pulled the main UP. At some point it needs to go DOWN, too.
If it still does not make sense I can raise the main tomorrow and get a better picture. I'm planning some major mods on that goosneck too.
Okay, so how is your main connected to the mast?DrV wrote:Are you kidding or what? Mine (2011 make) arrived without any kind of slugs whatsoever
I'm beginning to think that some of you have main sails without slugs. See slugs below. That might explain why your main is so hard to hoist.DrV wrote:Are you kidding or what? Mine (2011 make) arrived without any kind of slugs whatsoevermika wrote: It sounded like some of you implied this man's new boat was delivered without slugs on the main. Is that possible? My new M came with them and I don't recall that having been an upgrade when I ordered. Hmm.
"Ropes"? "Ropes"??!!??BOAT wrote:And all 'hull' was to pay if there were any loose ropes on desk!![]()
