26m C-head installation pictures?
- fishstalker7
Hi all,
Trying to see pics of the C-head installed on a 26m.
If you've done this particular mod...can you share your pics please?
I was surprised not to find this in the mods section.
Thank you in advance for your help!
Fair winds,
David
Fair winds,
David
Re: 26m C-head installation pictures
OK, in case there are others like me who are guessing that C-head means composting, please tell us if that is what it means.
- Jimmyt
Googled it- yes, you are correct. Composting toilet, 1 gallon urine jug; 5 gallon composting bucket in the version I saw. Looks like installation would consist of securing it to the floor. Probably prudent to check the height, though.
- fishstalker7
Re: 26m C-head installation pictures?
The C-Head is one of 3 main composting heads made by a former special forces medic here in FL. It is about 1/2 the price of the other two major brands and field repairable using basic materials. Sandy Graves, the designer/manufacturer, made a modified version specifically for the 26m (and adaptable to other boats) for a member of this forum. Since then, several folks here have installed them, but I've been unable to find pics of their installs in the mod section to gain insight/ideas on the 26m installation.
So...if you have one installed on a 26m...I'd love to see your install!
- kadet
Go to this old post and look at RobertB's install about half way down the page.
http://www.macgregorsailors.com/forum/v ... &start=105
- fishstalker7
- kmclemore
kadet wrote:Go to this old post and look at RobertB's install about half way down the page.
| ! | kmclemore: |
| BTW, folks, to link a specific posting within a thread, click on the little piece of paper icon beside the header at the top of the post you want to link. For example, see just above here where it says: " I'm referring to the little icon to the left ( So... to demonstrate... here's a link directly to the posting with the photos: http://www.macgregorsailors.com/forum/v ... 88#p264588 |
Sailor Dale
I took three photos of my simple installation last evening, but have not figured out how to post them. Very happy with the C-Head. I use one gallon ziplock bags to hold the composting medium. I use cedar bedding material (pellets) that I soak, pulverize to sawdust, then dry. Sounds complicated but I can make up many bags of material without a lot of effort. It is interesting to note that the 26M modified C-Head with the notch bottom doesn't mount square to the head compartment, but angles to follow the raised floor. I've mounted with simple cleats and ropes. I put a solid block of wood under the leading edge, as the notched unit does not reach the lower floor.
- fishstalker7
Sailor Dale,
That's the setup I am contemplating...I'd love to see your pics if you can figure it out or get moderator help to post them?
Thanks!
Thanks!
- fishstalker7
Big thank you to Sailor Dale for the pics (pm'd) and kadet for the link.
Here is the final result...hope it helps someone else!
