Winslow (Woodruff) Key Lost!!!!
Gazmn
Post by Gazmn »
I'm having an "Oh $H!t" moment.
I lost that half nickel sized widget that locks in the steering wheel :x
Who, how & where can I get another one... :?:
Anyone :cry: :?:
Ixneigh
Re: Winslow Key Lost!!!!
Post by Ixneigh »
Make one? Ss washers cut In half in a pinch?
Ix
You talking about this thing?
Gazmn
Post by Gazmn »
RussMT wrote:You talking about this thing?
Yep :)
Spector
Location: Calgary AB, 98 26X 'Cenoté' 2002 Yamaha 60 HP
Post by Spector »
Woodruff key..any bolt supply house should handle them
Gazmn
Re: Woodruff Key Lost!!!!
Post by Gazmn »
WOODRUFF KEY!!
No Wonder I couldn't find it Thank You!
Gazmn
Post by Gazmn »
Any clue what size we use???
Most Home Depot / Lowes / Sears Hardware will have hardware bits bins and they often have Woodruff keys. You need one that fits in the slot you have, so measure the width of the slot and that will tell you what size you need.
seahouse
Post by seahouse »
Hey Gazmn!
Note that in an emergency you might be able to reassemble the steering wheel without this key and still have functional steering.
I have never had this apart on these boats, but that is assuming the wheel is also on a locking taper that will snug up when a nut is turned. The Woodruff key / keyway/ keyseat is used to hold an index in one position and to absorb any torque that is beyond what the friction in the locking taper will absorb, so abrupt steering inputs will need to be avoided, although some turning/ slipping would not be catastrophic.
:wink:
Gazmn
Post by Gazmn »
Thanks Guys :)
In a few hrs I went from uh oh!... To Oh... ok I can fix this - & get extras :)
As always, you guys are GREAT. I learned What the Hull the thing is called & Where I can get it. Who's better than u guys?
Nobody 8)
For quick results, your best shot is a True Value or other franchise hardware store. I don't recall ever seeing key stock (straight) or Woodruff keys in a BORG, but every good hardware store stocks them in a variety of sizes.
shrektruck
Post by shrektruck »
New to sailing and I saw the title and thought I'd better see what a ''Winslow key'' is. Ha ha, True Value or Napa is probably your best bet.
Re: Winslow (Woodruff) Key Lost!!!!
 ! kmclemore:
Changed the title to make it a bit more searchable in the future.
Gazmn
Post by Gazmn »
Thanks Mod,
Kev you & The Boys do a great job. For Free :!:
Thank You :)
Gazmn wrote:Thanks Mod,
Thank You :)
Thanks! Nice to hear a little kudos once in a while.
