Has anyone had experience with the Evinrude Etec 50 hp 14" pitch x 13" diameter prop on the 26M or 26X. that they can share. The Evinrude part number is 177149. I hope this prop gives 5,500 rpm and good out of the hole performance. If someone has used this prop, what revs and speed do get at WOT and is there any cavitation?
I have been searching for the "right" prop and I am told this is as good as it gets. Any ideas?
Thanks
Phil King
Etec 50 HP Prop for 26M
No Fixed Address
waternwaves
- Kevin
- Location: Roseville, California USA "Toucan" Tanton 43 Cat Ketch
Oddly enough, I have a 14" diameter 13" pitch prop on my etec 50. That's how the dealer set it up and his recommendation for all-around use.
With that prop, 4 adults and full ballast the engine turns at 5100 WOT for about 18 mph. Best speed I've seen was 21 mph with one person and no ballast.
Can't comment on cavitation since I have nothing to compare to and wouldn't know it if I saw it.
waternwaves
No Fixed Address
Etec 50 Prop
Thanks for the input guys. My Initial reaction was an 11" pitch but I will try the 13" pitch and see how it goes. I'll report back.
