Air draught
- bastonjock
Air draught
Hi Guys
ive tried searching on this one and cant find an answer.
What is the clearance under a bridge that a mac26x can do with the mast down? the bridges on the nearest rivers to me have very low clearance plus they are tidal so what can i get under?
Matt
Matt
albion
- Location: Medina Ohio 2007 Mac26M Suzuki 50hp Hull#M1494g607
height
Bastonjock. If your boat is out of the water why dont you measure the height from the water line to the end of the mast at its highest point. That should give you a rough idea of the clearance you need.
Depends whether you intend to have the mast at the step or mounted to the pulpit. IIRC, the height of the masthead when the base is on the pulpit is about 10 feet, but I'd want a foot more clearance to be safe.
I believe the masthead would be higher off the water when tilted aft from the mast step ... added angle-height to avoid impact with the sliding hatch.
- bastonjock
- Lovekamp
- Location: Springfield, IL 2002 MacGregor 26X Nissan TLDI 50hp
With my mast off, I can fit under a 7' clearance without worry (railroad bridge on local lake); I'd worry at 6', though. Even at 7', I have to duck my head down. Mast crutch wouldn't clear at 7'.K9Kampers wrote:At this point, the issue isn't the height of the mast, but rather the hieght of your life-line stanchions on the cabin top.
LOUIS B HOLUB
Great description of how a Macabaago becomes a Macsubrino. Incidentally, Ive often wondered about Roger's hired help (I wonder if they speak English) ?eric3a wrote:I've go another silly suggestion (I rarely run out of those).
You can take mast off, then do that:
And you will fit under any bridge.
Eric
The way I would calculate the Mac bridge clearance would simply figure the length of the mast raising tool then add the distance to the vessel black stripe at the water line. If I were touring and came to a bridge site, I would definately be using the mast raising system. (making sure the cables dont tangle in the prop).
- bastonjock
my problem is that there is no easy acess to the sea except by using the ramps down to the tidal rivers,im hoping that i can get 4meters clearance at one particular bridge.
the air draught is 2.2 meters at HW,so im hoping for another 2meters from the tide,after that its the shifting sand banks i have to deal with
