Air draught
bastonjock
Air draught
Post by bastonjock »
Hi Guys
ive tried searching on this one and cant find an answer.
What is the clearance under a bridge that a mac26x can do with the mast down? the bridges on the nearest rivers to me have very low clearance plus they are tidal so what can i get under?
Matt
albion
Location: Medina Ohio 2007 Mac26M Suzuki 50hp Hull#M1494g607
height
Post by albion »
Bastonjock. If your boat is out of the water why dont you measure the height from the water line to the end of the mast at its highest point. That should give you a rough idea of the clearance you need.
James V
Post by James V »
The way that I fugure it, You have 6 feet headroom inside, The mast is about 3 feet higher. 10 feet (3 meter) is plenty, you may get by with 8 feet (2.5 meters ??)
The bridge height in the USA is not measured often and does change as much as 3 feet from markings.
Post by Frank C »
Depends whether you intend to have the mast at the step or mounted to the pulpit. IIRC, the height of the masthead when the base is on the pulpit is about 10 feet, but I'd want a foot more clearance to be safe.
I believe the masthead would be higher off the water when tilted aft from the mast step ... added angle-height to avoid impact with the sliding hatch.
Billy
Post by Billy »
Frank is right on an X. With the mast base on the pulpit, the masthead is about 10 feet off the ground. (Just measured,) With the mast base on the step, it is about 13-13.5 feet. (iirc) This was sitting on the trailer, now you can deduct about 2 feet for being on the water. Hope this helps.
Post by K9Kampers »
If you wanted to gain more clearance with the mast mounted on the bow pulpit, you can remove the mast crutch and lower the mast even more and support it where applicable. At this point, the issue isn't the height of the mast, but rather the hieght of your life-line stanchions on the cabin top.
bastonjock
guess ill have to go and hang off of the bridge with a measuring tape,some of the bridges have a 2.4meter clearance some others are 3.6m.
nothing is ever straight forward :(
James V
Post by James V »
Most of us do not go under bridges that low.
eric3a
Post by eric3a »
Lovekamp
Location: Springfield, IL 2002 MacGregor 26X Nissan TLDI 50hp
Post by Lovekamp »
K9Kampers wrote:At this point, the issue isn't the height of the mast, but rather the hieght of your life-line stanchions on the cabin top.
With my mast off, I can fit under a 7' clearance without worry (railroad bridge on local lake); I'd worry at 6', though. Even at 7', I have to duck my head down. Mast crutch wouldn't clear at 7'.
eric3a
Post by eric3a »
LOUIS B HOLUB
Post by LOUIS B HOLUB »
eric3a wrote:I've go another silly suggestion (I rarely run out of those).
You can take mast off, then do that:
And you will fit under any bridge.
Eric
Great description of how a Macabaago becomes a Macsubrino. Incidentally, Ive often wondered about Roger's hired help (I wonder if they speak English) ?
:D
The way I would calculate the Mac bridge clearance would simply figure the length of the mast raising tool then add the distance to the vessel black stripe at the water line. If I were touring and came to a bridge site, I would definately be using the mast raising system. (making sure the cables dont tangle in the prop).
bastonjock
my problem is that there is no easy acess to the sea except by using the ramps down to the tidal rivers,im hoping that i can get 4meters clearance at one particular bridge.
the air draught is 2.2 meters at HW,so im hoping for another 2meters from the tide,after that its the shifting sand banks i have to deal with :D
eric3a
Post by eric3a »
Not quite that simple. On the M, if you take the mast out of the arch, the spreaders will hit the cabin top and you will bend them.
