watch out for cable bind
MMMike
Post by MMMike »
:( Matey
Went down to the mooring for my first solo sail this season( busy).
It was a blowin 18 to 24 ( reading off my new TACK TICKS )
Uncoverd the sail , wheel etc.
Lowered the Tohatsu 50 and got it runnin.
Went to the bow an released the mooring, ran back and shifted to forward
The fifty reved up and the prop never moved.
Grabed the main haylard and got the main sail stuck in the lazy jacks.
NICE.............. Called the club tender for help.. faster guys, blowing toward the rocks.
The short of it , is the shift cable broke from raising and lowering the motor. It pinches about 6 to 8 inches from the motor.
Local dealer had a generic one.. Pulled out a c- note and bent over.
Turned out it was only $23 bucks. I am gonna pac a spare.
2000 x
Thought you's should know.
MMMike
2000 x Figment
Narr. Bay RI
Richard O'Brien
tfextreme
Post by Richard O'Brien »
Hi Mike. You might try TFXtreme cableshttp://www.teleflexmorse.com/Marine/tel ... .asp?ID=46 There are similar problems with the M, and this is pretty much solved by switching to these cables. They cost a tiny bit more, but can bend in very small radii.
